POINTCLOUDCACHEFOLDER system variable
Disk cache folder
The file path(s) used to store point cloud cache files.
Separate file paths with semicolons (;).
Note:
Multiple paths are supported. The first one will be used for adding new cached/preprocessed data.
BricsCAD only
| Type: |
String Standard |
| Saved in: |
Preference |
| Default value: |
C:\Users\%username%\AppData\Roaming\Bricsys\BricsCAD\V26x64\en_US\PointCloudCache |
