POINTCLOUDDOLLHOUSE system variable
Enable/disable dollhouse render mode
When true, the interior of the point cloud is visible because points with normal vector pointing away from the viewpoint are not shown.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Default value: |
0 |
| Possible options: |
0: Normal rendering: all points are shown 1: Dollhouse rendering: points with normal pointing away from the viewpoint are not shown |
