POINTCLOUDNORMALS system variable
Normal calculation
Calculates normals during point cloud preprocessing, used to identify planar (flat surfaces) such as walls and floors.
Note: Applies if the POINTCLOUDHSPC system variable is on (1).
When a point cloud is structured (in other words it has bubbles), the normal vectors will be computed automatically during preprocessing.
Structured point clouds already available in the cache in HSPC which have no normal vectors yet can be computed with the POINTCLOUDNORMALS command.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Preference |
| Default value: |
On |
| Possible values: |
Off (0): Disable normal calculation during HSPC preprocessing. On (1): Enable normal calculation during HSPC preprocessing. |
