POPERATIONSCOLOR system variable
Parametric operations color
Controls the color of the parametric operations' geometry.
BricsCAD only
Type:
String
Saved in:
Registry
Default value:
RGB:238,173,60
Related commands
  • PBLOCKOPERATIONSDISPLAY command
Related variables
  • PBLOCKREFERENCEOPERATIONSVISUALIZATION system variable
Related information
  • 2D parametric blocks
© 2026 BricsCAD NV. All rights reserved.Privacy statement -Terms of use -Cookie statement
