PRINTPDFPREVIEW system variable
Print As PDF Preview
Controls if the Print As PDF preview uses the system default PDF viewer or an internal program window.
BricsCAD only
Type:
Short
Saved in:
Preference
Range:
0 to 1
Default value:
1
Possible options:
0: Use internal window
1: Use external viewer
