PROMPTOPTIONFORMAT system variable
Prompt option format
Specifies how command options are displayed in the Command line prompt. A command option has a keyword, a description and a shortcut. The shortcut is the keyword without lower case characters (a-z).
e.g. the third option of the CIRCLE command:
Keyword = TanTanRad
Description = Tangent-Tangent-Radius
Shortcut = TTR
BricsCAD only
| Type: |
Short |
| Saved in: |
Preference |
| Range: |
0 to 4 |
| Default value: |
0 |
| Possible values: |
