PROMPTOPTIONTRANSLATEKEYWORDS system variable
Prompt option translate keywords
Loads translated command option keywords.
If disabled, English keywords are used and global shortcuts can be used without an underscore.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Preference |
| Default value: |
On |
| Possible values: |
Off (0): Don’t load translations of keywords On (1): Load translations of keywords |
