PROPAGATESEARCHSPACE system variable
Search space
Asks for a search space during the BIMPROPAGATE command. Limits the locations and entity can be propagated to.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value:
Off
Related commands
  • BIMPROPAGATE command
  • BIMPROPAGATEEDGES command
  • BIMPROPAGATECORNER command
  • BIMPROPAGATELINEAR command
  • BIMPROPAGATEPATTERN command
  • BIMPROPAGATEPLANAR command
