PROPAGATETOLERANCE system variable
Position tolerance
The position tolerance used for the BIMPROPAGATE command, in drawing units.
BricsCAD only
Type:
Real
Saved in:
Registry
Default value: 0.00001
Related commands
  • BIMPROPAGATE command
  • BIMPROPAGATECORNER command
  • BIMPROPAGATEEDGES command
  • BIMPROPAGATELINEAR command
  • BIMPROPAGATEPATTERN command
  • BIMPROPAGATEPLANAR command
