PROPERTYPREVIEW system variable
Property preview
Specifies whether selected entities will immediately show property changes when hovering combobox list values in the Properties panel.
Type: | Boolean |
Saved in: |
Registry |
Default value: | On |
Possible values: |
Off (0): Selected entities won’t show property changes when hovering combobox list values in the Properties panel On (1): Selected entities will show property changes when hovering combobox list values in the Properties panel |
