PROPUNITS system variable
Property units
Automatically formats length, area, volume, dimension and mass units, in panels and input boxes. For example, 2000mm will be displayed as 2m.
Applies if the INSUNITS system variable is active.
BricsCAD only
| Type: | Short |
| Saved in: |
Registry |
| Range: |
0 to 255 |
| Default value: |
47 |
| Possible options: |
1: Format length properties 2: Format area properties 4: Format volume properties 8: (Reserved) 16: Format dynamic dimensions 32: Format mass properties |
