QAFLAGS system variable
Quality Assurance flags
Internal system variable with flags for Quality Assurance and testing.
Note: This is subject to change, and not intended for regular use. Some of these options could have unpredictable or unwanted side-effects.
| Type: | Short |
| Saved in: | Registry |
| Range: |
0 to 32767 |
| Default value: |
0 |
| Possible options: |
0: Red device: no low quality draw 2: No pause during text screen listings 4: No 'alert' dialogs (text display instead) 8: Have Warnings act as Errors and stop scripts 16: Minimal audit report 32: Disable window recreation on switch between 2d and rendered visual styles. 64: Enable various performance measurements printed as info prompts 128: Parallel vectorization: EnableSchedulerLogOutput 256: Cmd message enable 512: Dcl take screenshot 1024: Print time on statusbar 2048: No crash dump file 4096: Create assert log file 8192: Create RED files during rendering 16384: Parallel vectorization performance measurement |
