QSELECTAUTOCLOSE system variable
Quick Select auto close
Controls whether there’s an automatic switch from Quick Select to properties panel after a selection set is updated.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Preference |
| Default value: |
0 |
| Possible values: |
Off (0): Remain in Quick Select mode after selection set update On (1): Automatically switch to properties panel after selection set update |
