QUADCOMMANDLAUNCH system variable
Quad default command launch
Controls how the first Quad command is activated.
The default quad command depends on which command from the quad is used last.
- When 0: hover over an entity to see the quad and click on the command button to launch the command.
- When 1: hover over an entity to see the quad and right-click on the entity to launch the command, instead of clicking on the command button first.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 1 |
| Default value: |
0 |
| Possible values: |
0: Do not launch the first Quad command on right-click 1: Launch the first Quad command on right-click when the Quad is displayed |
