QUADCOMMANDLAUNCH system variable
Quad default command launch
Controls how the first Quad command is activated.
The default quad command depends on which command from the quad is used last.
  • When 0: hover over an entity to see the quad and click on the command button to launch the command.
  • When 1: hover over an entity to see the quad and right-click on the entity to launch the command, instead of clicking on the command button first.
BricsCAD only
Type:
Short
Saved in:
Registry
Range:
0 to 1
Default value:
0
Possible values:
0: Do not launch the first Quad command on right-click
1: Launch the first Quad command on right-click when the Quad is displayed
