QUADDISPLAY system variable
Quad display
Determines when to display the Quad.
BricsCAD only
Note: When the SELECTIONPREVIEW system variable is Off, the Display the Quad when the cursor hovers over an entity option of the QUADDISPLAY system variable is ignored, and the Quad is not displayed.
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
-15 to 15 |
| Default value: |
3 |
| Possible options: |
negative: Switch off Quad 0: Do not display the Quad 1: Display the Quad when the cursor hovers over an entity 2: Display the Quad when entities are selected 4: Display the Quad on right click 8: Suppress the Quad on hover, when entities are selected |
