QUADDISPLAY system variable
Quad display
Determines when to display the quad.
BricsCAD only
| Type: | Short |
| Saved in: | Registry |
| Range: |
-15 to 15 |
| Default value: |
5 |
| Possible options: |
negative: Switch off quad 0: Do not display the Quad 1: Display the Quad when the cursor hovers on an entity 2: Display the Quad when entities are selected 4: Display the Quad on right click 8: Suppress the Quad on hover, when entities are selected |
