REDHILITE_HIDDENEDGE_ALPHA system variable
Edge opacity
Controls the transparency hidden edges, when a whole entity is selected, if the REDHILITEFULL_EDGE_SHOWHIDDEN system variable is on (1).
Values between 0 and 100 are accepted.
BricsCAD only
BricsCAD only
| Type: | Short |
| Saved in: | Preference |
| Range: |
0 to 100 |
| Default value: |
50 |
