REDHILITEPARTIAL_SELECTEDEDGEGLOW_THICKNESS system variable
Glow thickness
Controls the thickness of the glow effect on an edge, when selected, in pixels. See also the REDHILITEPARTIAL_SELECTEDEDGE_SHOWGLOW system variable.
Values between 0.0 and 20.0 are accepted.
BricsCAD only
| Type: | Real |
| Saved in: | Preference |
| Range: |
0.0 to 20.0 |
| Default value: |
3.0 |
