REDUCELENGTHVALUE system variable
Reduce Length Value
Sets default flow fitting reduce length value.
BricsCAD only
Type: |
Real |
Saved in: |
Drawing |
Range: |
0.0 to 1e6 |
Default value: |
0.5 |
BricsCAD only
Type: |
Real |
Saved in: |
Drawing |
Range: |
0.0 to 1e6 |
Default value: |
0.5 |
REDUCELENGTHVALUE system variable - BricsCAD BIM | Bricsys Help Center
