REGENMODE system variable
Regeneration mode
Toggles automatic regeneration on/off. See also the REGENAUTO command.
BricsCAD will regenerate the display automatically when REGENMODE is On, but in a few cases a forced regeneration of the drawing might be necessary. This is done by the REGEN command.
| Type: | Boolean |
| Saved in: | Drawing |
| Default value: | On |
| Possible values: |
Off (0): Turn off REGENAUTO command On (1): Turn on REGENAUTO command |
