RENDERUSINGHARDWARE system variable
Render using hardware
Controls if hardware is used to render. Switch this off if there are problems caused by the graphics card or driver.
A restart may be required.
BricsCAD only
| Type: | Short |
| Saved in: | Preference |
| Range: |
0 to 3 |
| Default value: |
1 |
| Possible options: |
0: Use software only (slower) 1: Prefer hardware (faster) 2: Prefer software (only for testing purposes) 3: Use hardware only (only for testing purposes) |
