RENDERUSINGHARDWARE system variable
Render using hardware
Specifies if rendering should use the hardware. Switch this off if you encounter rendering problems caused by graphic card or driver. The application might need to be restarted after changing this setting.
BricsCAD only
| Type: | Short |
| Saved in: | Preference |
| Range: |
0 to 3 |
| Default value: |
1 |
| Possible values: |
0: Use software only (slower) 1: Prefer hardware (faster) 2: Prefer software (only for testing purposes) 3: Use hardware only (only for testing purposes) |
