REVCLOUDGRIPS system variable
Revision cloud grips
Uses custom grips for revision clouds.
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
On |
| Possible values: |
Off (0): Displays grips on every arc segment On (1): Displays only the most relevant grips |
