REVCLOUDMINARCLENGTH system variable
Revision cloud default minimum arc length
Controls the default minimum arc length for revision clouds. The minimum arc length is multiplied by the value of the DIMSCALE system variable.
| Type: | Real |
| Saved in: | Registry |
| Default value: | 0.375 |
