REVCLOUDPROPMAXVERTICES system variable
Revision cloud property maximum vertices
Controls the number of revision cloud vertices above which geometric properties are not shown.
Note: Values between 1 and 1000000 are accepted.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
1 to 1000000 |
| Default value: |
10000 |
