RIBBONDOCKEDHEIGHT system variable
Ribbon docked height
Controls the height of the Ribbon.
Values between 0 and 500 are accepted. Values lower than the current Ribbon content will be disregarded.
A value of 0 means Automatic height.
Note: Values below 124 are effective only in certain circumstances.
| Type: | Short |
| Saved in: | Registry |
| Range: |
0 to 500 |
| Default value: |
0 |
