RIBBONGRAYOUT system variable
Ribbon Grayout Mechanism On/Off
Toggles the grayout mechanism in the ribbon On or Off.
Note: A restart may be required.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
1 |
| Possible values: |
0: The grayout mechanism in the ribbon is disabled. 1: The grayout mechanism in the ribbon is activated. |
