RIBBONSETTINGSENABLED system variable
Ribbon interface settings control on/off
Toggles the display of the Interface Settings control in the ribbon on/off.
Note: A restart may be required.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
1 |
| Possible values: |
0: Do not display the Interface Settings control in the ribbon 1: Display the Interface Settings control in the ribbon |
