RIBBONSTATE system variable
Ribbon state (Read Only)
Indicates if the Ribbon is on.
The ribbon can be closed with the RIBBONCLOSE command and can be displayed with the RIBBON command.
| Type: | Boolean |
| Saved in: | Registry |
| Default value: | Off |
| Possible values: |
Off (0): Don’t show ribbon bar On (1): Show ribbon bar |
