RIBBONSTATE system variable
Ribbon state
Indicates whether the ribbon bar is shown or not. The ribbon can be closed with the RIBBONCLOSE command and can be displayed with the RIBBON command.
Read-only
| Type: | Boolean |
| Saved in: | Registry |
| Default value: | Off |
| Possible values: | Off (0): Don’t show ribbon bar RegistryOn (1): Show ribbon bar |
