RIBBONSTATE system variable
Ribbon state (Read Only)
Indicates if the Ribbon is on.
The Ribbon can be closed with the RIBBONCLOSE command and can be displayed with the RIBBON command.
Type:
Boolean
Saved in:
Registry
Default value:
Off
Possible values:
Off (0): Don’t show Ribbon bar
On (1): Show Ribbon bar
