RULERTEXTCOLOR system variable
Ruler Text Color
Controls the text color of the Manipulator ruler.
Applies only if the RULERDISPLAY system variable is on (1).
| Type: |
String |
| Saved in: |
Preference |
| Default value: |
#c8c8c8 |
| Possible values: |
RGB color code Hex color code Index color code |
A new value for the variable can be entered in the Command line.
