account
translation
Bricsys Help Center
RULERTEXTCOLOR system variable
Ruler Text Color
Specifies the color of the text on the ruler if the RULERDISPLAY system variable is on.
Type:
String
Saved in:
Registry
Default value:
#c8c8c8
Possible values:
RGB color code
Hex color code
Index color code
A new value for the variable can be entered in the command bar.
Related variables
  • MANIPULATOR system variable
  • RULERDISPLAY system variable
Related information
  • The manipulator
© 2025 Bricsys NV. All rights reserved.Privacy statement -Terms of use -Cookie statement
