RUNASLEVEL system variable
Run as license level
Runs the program in a different (lower) level than the licensed level. If the licensed level is lower than RUNASLEVEL, RUNASLEVEL is ignored.
Note: A restart is required.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 5 |
| Default value: |
5 |
| Possible options: |
0: Lite 1: Pro 2: (Obsolete) 3: BIM 4: Mechanical 5: Ultimate |
