RUNASLEVEL system variable
Run as license level
Specifies at which license level to run BricsCAD. The new level will be in use after restarting. If the purchased license level is lower than RUNASLEVEL, RUNASLEVEL is ignored.
BricsCAD only
| Type: | Short |
| Saved in: |
Registry |
| Range: |
0 to 5 |
| Default value: |
5 |
| Possible values: |
0: Lite 1: Pro 2: Platinum (Obsolete) 3: BIM 4: Mechanical 5: Ultimate |
