SAVETIME system variable
Save time interval
Controls the interval for automatic saves, in minutes.
Values between 0 and 240 are accepted. If set to zero, automatic saves are turned off.
Type:
Short
Saved in:
Registry
Range:
0 to 240
Default value:
20
Possible options:
0: Turn off automatic saving
1 - 240: Saves the drawing at intervals specified (in minutes)
