SAVETIME system variable
Save time interval
Controls the interval for automatic saves, in minutes.
Values between 0 and 240 are accepted. If set to zero, automatic saves are turned off.
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 240 |
| Default value: |
60 |
| Possible values: |
0: Turn off automatic saving 1 - 240: Saves the drawing at intervals specified (in minutes) |
