SCRLHIST system variable
Scroll history
Controls the number of lines stored in the history of the Command line.
Values between 0 and 256 are accepted.
BricsCAD only
| Type: |
 Short  |
| Saved in: |
 Registry  |
| Range: |
 0 or greater  |
| Default value: |
 256  |
BricsCAD only
| Type: |
 Short  |
| Saved in: |
 Registry  |
| Range: |
 0 or greater  |
| Default value: |
 256  |
