SECTIONOFFSETSTEP system variable
Section plane offset step
Step size used for increments of the section plane offset property.
When set to a negative value, BricsCAD determines the step size automatically based on the section plane properties.
BricsCAD only
| Type: |
Real |
| Saved in: |
Preference |
| Default value: | -1 |
