SECTIONRESULTINTERVAL system variable
Section result interval
The distance between generated section blocks in model space.
BricsCAD only
| Type: |
Real |
| Saved in: |
Drawing |
| Default value: | 400.0 |
Note:
- If INSUNITS=inches (1), the default value of SECTIONRESULTINTERVAL is 400.0.
- If INSUNITS=millimeters (4), the default value of SECTIONRESULTINTERVAL is 10000.0.
- If INSUNITS=centimeters (5), the default value of SECTIONRESULTINTERVAL is 1000.0.
- If INSUNITS=meters (6), the default value of SECTIONRESULTINTERVAL is 10.0.
