SECTIONSCALE system variable
Section scale
The default scale used to generate sections.
Values between 0.000001 and 1000000.0 are accepted.
BricsCAD only
Type: |
Real |
Saved in: |
Registry |
Default value: | 0.02 |
BricsCAD only
Type: |
Real |
Saved in: |
Registry |
SECTIONSCALE system variable - BricsCAD BIM | Bricsys Help Center
