SECTIONSHEETSETTEMPLATEMETRIC system variable
Section sheet set template metric
The file path for Sheet Set file (dst), used as template for a new section. Applies only when the MEASUREMENT system variable is 1 (metric).
The default file is BIM-section-metric.dst, which can be found in the {SheetSetTemplatePath} folder.
BricsCAD only
| Type: |
String |
| Saved in: |
Registry |
| Default value: | BIM-section-metric.dst |
Note: The SECTIONSHEETSETTEMPLATEMETRIC system variable is only available for BIM and Ultimate license levels.
