SELECTIONAREAOPACITY system variable
Selection area opacity
Controls the transparency of the selection area. Applies only when SELECTIONAREA setting is on.
Values between 0 and 100 are accepted.
- A value of zero means Fully Transparent.
- A value of 100 means fully opaque.
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 100 |
| Default value: |
25 |
