SELECTIONCYCLING system variable
Selection cycling
Controls the display options associated with overlapping entities and selection cycling.
Note: When the SELECTIONPREVIEW system variable is Off, the SELECTIONCYCLING system variable is ignored, and no badge or selection dialog box is displayed when you hover the cursor over entities.
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
-2 to 2 |
| Default value: |
0 |
| Possible options: |
-2: Selection cycling is turned off, but the setting is stored (toggled value 2) -1: Selection cycling is turned off, but the setting is stored (toggled value 1) 0: The display options are turned off 1: A badge is displayed when hovering over entities which overlap 2: A badge and the selection dialog are both displayed |
Note:
- Use the keyboard shortcut Ctrl + W to toggle on or off the current setting of the SELECTIONCYCLING system variable.
- The QUADHIDEDELAY system variable controls the hide delay time of the selection dialog box.
