SELECTSIMILARMODE system variable
Match options for SELECTSIMILAR
Controls which properties must match for the SELECTSIMILAR command. For this command to operate as intended, at least one property must be turned on. When all properties are turned off, this command selects only the entity(ies) you pick at the Select entities prompt.
Type:
Short
Saved in:
Registry
Range:
0 to 255
Default value:
130
Possible options:
0: Entity type
1: Color
2: Layer
4: Linetype
8: Linetype scale
16: Lineweight
32: Plot style
64: Entity style
128: Name
