SETBYLAYERMODE system variable
Set by layer mode
Controls which layer properties are applied with the SETBYLAYER command.
Type:
Short
Saved in:
Registry
Range:
0 to 255
Default value:
255
Possible options:
0: None
1: Color
2: Linetype
4: Lineweight
8: Material
16: Plot style
32: ByBlock
64: Blocks
128: Transparency
