SETBYLAYERMODE system variable
Options for SETBYLAYERMODE
Specifies which layer properties would be applied by SETBYLAYER command.
| Type: | Short |
| Saved in: | Registry |
| Range: | 0 to 255 |
| Default value: | 255 |
| Possible values: | 0: None 1: Color 2: Linetype 4: Lineweight 8: Material 16: Plot style 32: ByBlock 64: Blocks 128: Transparency |
