SHEETSETAUTOBACKUP system variable
Sheet set automatic backup
Creates a backup file when a Sheet Set file is opened.
The backup files must have the same name as the Sheet Set file but with a 'ds$' extension.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Preference |
| Default value: |
On |
| Possible values: |
Off (0): Don’t create backup files On (1): Create backup files |
