SHORTCUTMENU system variable
Shortcut menus
Controls the status of the DEFAULT, EDIT and COMMAND (right-click) context menus.
| Type: | Short |
| Saved in: | Registry |
| Range: |
0 to 63 |
| Default value: |
19 |
| Possible options: |
0: Disable all Default, Edit, and Command mode shortcut menus 1: Enable Default mode shortcut menus 2: Enable Edit mode shortcut menus 4: Enable Command mode shortcut menus (available whenever a command is active) 8: Enable Command mode shortcut menus only when command options are currently available from the Command line 16: Enable a shortcut menu when the right mouse is held down 32: Repeat command with short right click when entities are selected and Quad is not shown |
